How to get real-time lens prototype costs in OpticStudio
Design for manufacture is a phrase commonly used to describe how manufacturing considerations are incorporated into the optical design process. OpticStudio offers several capabilities that support design for manufacture, and the Cost Estimator takes the concept to new heights by allowing users to get real-time cost estimates direct from manufacturers. This tool uses an XML file, generated from data in the ISO 10110 drawing to ensure a seamless data exchange.
Authored By Zachary Derocher
Downloads
Article Attachments
OpticStudio offers several capabilities that support design for manufacture, and the Cost Estimator takes the concept to new heights. The tool allows you to send lens data to manufacturers and get real-time cost estimates. The designer can then see the cost impact of lens shape, size, material, coatings, quality and quantity. This capability is unprecedented in the optical design software industry.
This article will provide a tutorial on how to use the Cost Estimator tool.
Registering with manufacturers
Prior to using the Cost Estimator, users must register with the supported manufacturer. Below you will find instructions on registering with supported manufacturers.
Optimax
For a complete description of usage of the Optimax estimator, please refer to the documentation available for download in the Article Attachments section above.
Go to the website for the Optimax Estimator here and click the link to register.
Once you have registered with the desired manufacturer, open OpticStudio and click Manage Providers in the Cost Estimator section of the System Explorer. Click on the desired provider and enter your username and password provided by the vendor. After closing the dialog, the information will be saved and the estimator will be ready to use.
Password information can be saved in an encrypted format using the Export Provider Data button in the System Explorer. Later, when the password needs to be reloaded, it can be imported using the Import Provider Data button.
Using the Cost Estimator
The Cost Estimator can be found in two locations in OpticStudio. It can be launched from the Tolerance ribbon or from the dedicated tab in the ISO 10110 drawing:
The tool requires several pieces of information provided in the ISO 10110 drawing in order to provide cost estimates. The lens shape, size, material, coatings, and quality (tolerances) are all needed. Tolerances should be pulled in from the tolerance data editor by clicking the “Reset from TDE” button in the tolerance data editor (TDE). Please note that not all settings in the ISO inputs are considered for cost estimation; the inputs utilized in cost estimation vary depending on the providor used. See below for providor-specific information. Once all this information is in the ISO 10110 drawing, the user can proceed to define the settings for the estimator.
Optimax Cost Estimator supported parameters
When using Optimax as the Cost Estimator, the following fields (highlighted in the images below) are considered:
The definitions of the Diameter inputs in the first image above are as follows:
Effective Diameter: This is the clear aperture for the surface (area over which form and cosmetic tolerances must be met).
Diameter: This is the effective diameter plus the chip zone (over which the surface form continues). For concave surfaces, it is also called the opening.
Diameter (flat): This is the overall finished part diameter. For concave surfaces, it is the diameter of the opening plus the flat area (sag face). For convex surfaces, the diameter and diameter (flat) are usually the same value.
Generating the Cost Estimate
When opening the Cost Estimator from the ISO 10110 drawing, the currently configured lens will be used for cost estimates. The user defines the manufacturer and quantities they would like estimates for. Multiple quantities can be quoted simultaneously by using commas to separate them.
Once the settings are defined properly, click OK and the estimator will obtain estimates from the selected providers. If the unit costs are returned as zero, check the messages for errors in the lens data sent.
The Cost Estimator launched from the Tolerance ribbon offers similar functionality with a few more options. This tool loads lens data from an XML file (generated by the ISO 10110 drawing) or directly from a ZMX file. Alternately the user can create a new part directly within the tool by entering the lens data manually. Multiple lenses can be loaded simultaneously. Selecting a specific part from the list at the top of the tool will list its surface and material data in the center of the dialog. Cost estimates are provided at the bottom of the dialog after pressing Refresh Estimates.
Vendor limitations and information
Cost estimate providors have some limitations in the values that can be used, in either the lens prescription, cost estimator settings, or tolerances. Some of the limitations and other pertinent informations for currently supported providors are provided below.
Optimax
Please refer to the Optimax Cost Estimator documentation, provided as an article attachment, for a full set of information. This is a useful tool for understanding how lens properties affect the estimates returned.
The Estimator is designed around prototype optics that Optimax can deliver in 1 week, and is thus limited in scope to a set of boundary conditions. For example, the glasses used in the lens prescription must be from OpticStudio's default OPTIMAX glass catalog. Another example is that there are minimum values allowed on tolerance inputs (precision limitations). For a complete set of cost estimate boundary conditions, please refer to the Optimax Cost Estimator Documentation. Please note that the actual full scope of manufacturing capabilities at Optimax are much broader.
When using Optimax as the provider, error messages will be returned if the data submitted violates any of the above limitations. Those error codes are listed below.
001
The submitted XML File has transmission errors. Please resubmit or contact Zemax customer service.
002
Missing part side.
003
Invalid surface type on Left Surface. Only Standard and Even Aspheres are supported at this time.
004
Invalid surface type on Right Surface. Only Standard and Even Aspheres are supported at this time.
100
Log In failed. To register for the Optimax Estimator go to estimator.optimaxsi.com and click Register.
101
Your Estimator account has expired. To renew contact estimator@optimaxsi.com
110
Quantity must be between 1 and 10 for estimates.
111
Radius must be between 10mm and 1500mm.
112
Edge Thickness at diameter (flat) must be 1mm or greater.
113
Left Surface: R/numbers faster than R/1 are not supported.
114
Right Surface: R/numbers faster than R/1 are not supported.
115
Left surface is plano and 3/A must be more than 1fr for Optimax Cost Estimates.
116
Right surface is plano and 3/A must be more than 1fr for Optimax Cost Estimates.
117
Left Surface: Form Error 3/B is required for Optimax Cost Estimates.
118
Right Surface: Form Error 3/B is required for Optimax Cost Estimates.
119
Left Surface: Form Error 3/C is not supported in Optimax Cost Estimates.
120
Right Surface: Form Error 3/C is not supported in Optimax Cost Estimates.
121
Left Surface: RMS values for Form Error are not considered in Optimax Cost Estimates.
122
Right Surface: RMS values for Form Error are not considered in Optimax Cost Estimates.
123
Left surface is plano and must have power set for Optimax Cost Estimates.
124
Right surface is plano and must have power set for Optimax Cost Estimates.
125
Left Surface: Must have either radius or a power or both for Optimax Cost Estimates.
126
Right Surface: Must have either radius or a power or both for Optimax Cost Estimates.
127
Left surface: Conic Constant tolerances are not considered in Optimax Cost Estimates.
128
Right surface: Conic Constant tolerances are not considered in Optimax Cost Estimates.
200
The material that you have specified is not an Optimax Preferred Glass. Optimax processes most optical materials. Please contact a Sales Engineer.
201
Left Surface: The coating that you have specified is not an Optimax Coating. Please select an Optimax coating from the catalog.
202
Right Surface: The coating that you have specified is not an Optimax Coating. Please select an Optimax coating from the catalog.
203
Lens thickness is greater than standard glass strip thickness as supplied by glass manufacturer.
204
Lens width greater than glass strip width as supplied by glass manufacturer.
300
Material Thickness must be between 2mm and 100mm.
301
Material Thickness tolerance must be 0.05mm or greater total.
302
Left Surface: ISO Grade Number (5/A) must be greater or equal to 0.063
303
Right Surface: ISO Grade Number (5/A) must be greater or equal to 0.063
304
Left Surface: ISO Surface Imperfection (5/L_A'') must be greater than or equal to 0.001
305
Right Surface: ISO Surface Imperfection  (5/L_A'') must be greater than or equal to 0.001
306
Left Surface: Clear Aperture cannot be greater than 90% of the diameter (flat).
307
Right Surface: Clear Aperture cannot be greater than 90% of the diameter (flat).
308
Left Surface: Clear Aperture cannot be greater than 90% of the diameter (opening).
309
Right Surface: Clear Aperture cannot be greater than 90% of the diameter (opening).
310
Left Surface: Diameter (opening) cannot be larger than Diameter (flat).
311
Right Surface: Diameter (opening) cannot be larger than Diameter (flat).
312
Left Surface: Diameter (opening) cannot be less than Clear Aperture.
313
Right Surface: Diameter (opening) cannot be more than Clear Aperture.
314
Diameter (flat) with tolerances should be between {minimum-value} mm and 100mm.
315
The Material Thickness to Diameter (flat) aspect ratio should not be less than 1/5th of the Diameter (flat) and not more than 10 times the Diameter (flat).
316
Diameter (flat) tolerance must be 0.015mm or greater total.
317
Left Surface: The Diameter tolerance converts to a sag tolerance that is too small to measure (limit is +/-0.015 mm).
318
Right Surface: The Diameter tolerance converts to a sag tolerance that is too small to measure (limit is +/-0.015 mm).
319
Left Surface: Power Tolerance must be 1 fringe or greater.
320
Right Surface: Power Tolerance must be 1 fringe or greater.
321
Left Surface: Form Tolerance B should be no less than 0.2 fringes.
322
Right Surface: Form Tolerance B should be no less than 0.2 fringes.
323
The calculated Edge Thickness Difference tolerance is too small for the Cost Estimator.  Must be 0.005mm or greater. Please revise lens attributes or contact sales@optimaxsi.com for more information.
324
The RMS Roughness must be 10 Angstroms or greater.
325
{Side} aspheric surface: minimum local radius too small for the standard manufacturing tool. It may be possible, after deeper examination, to produce a shorter local radius with special tooling.  Please contact your Optimax Sales Engineer for more information.
326
{Side} aspheric surface: slope too high for the standard manufacturing tool. It may be possible, after deeper examination, to produce a shorter normal angle with special tooling.  Please contact your Optimax Sales Engineer for more information.
327
{Side} aspheric surface: sag of surface too large for profilometric measurement.  Please contact your Optimax Sales Engineer for more information.
KA-01516
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
