How to convert FWHM measurements to 1/(e^2) halfwidths
Sometimes, manufacturers provide Gaussian beam data as Full Width Half Maximum (FWHM) measurements, but OpticStudio uses the 1/e2 measure of beam width. This article describes how to convert FWHM measurements to 1/e2 halfwidth measurements.
Authored By Dan Hill
For Gaussian beam size measurements, OpticStudio uses the 1/e2 half-width point, which means the intensity has fallen to about 13.5% of the peak. However, often times manufacturer’s data sheets provide only Full Width Half Maximum (FWHM) measurements and not 1/e2 half-widths.
The relationship between the FWHM and 1/e2 halfwidth of a gaussian beam
For a truly TEM00, rotationally symmetric & normalized Gaussian beam, there is a linear relationship between the FWHM and 1/e2 values.
Gaussian_Beam_Characteristics
The intensity of a Gaussian beam goes as:
Intensity_of_a_Gaussian_beam
where w is the half width of the beam to the 1/e2 intensity point at some distance from the waist along the propagation axis, and r is the radial distance from the center of the beam. The width, w, at some z position is given by:
The_width_w_at_some_z_position
where w0 is the waist radius at the 1/e2 point. For a normalized Gaussian beam, we know that the FWHM is the point at which the beam reaches half of the peak intensity. As a result, our equation simplifies to:
Simplified_equation
The FWHM is the full width of the beam at half of the maximum intensity, so we need to divide this value by 2 so that we can replace it with r, the radial size.
divide_this_value_by_2
Simplifying, we get:
Simplified_equation_2
Taking the natural log of both sides, and bringing the constant to the other side of the equation yields:
Final_equation
Solving for w, the relationship between the FWHM and the 1/e2 intensity point becomes:
After_solving_for_w
KA-01545
Was this article helpful?
29 out of 39 found this helpful
Comments
0 comments
