How to Use the Tolerancing Cache
This article explains the benefits of the tolerancing cache feature. This article also warns when it may be inappropriate to use this feature.
Authored By Andrew Locke
Tolerancing can be one of the most time consuming aspects of optical design. In fact, tolerancing often takes longer than all of the other stages of optical design combined!
Using the cache features available in OpticStudio, the tolerancing process can be greatly streamlined in many circumstances.
The Tolerancing Cache
One of the reasons tolerancing can be so time consuming it is traditionally an “all-or-none” type of process. In other words, if you change the range for a single tolerance perturbation and want to determine the sensitivity, OpticStudio will recompute the sensitivity of all tolerance perturbation operands. In a typical optical design, there may be dozens of tolerance operands. As such, it often takes several minutes or more to compute the sensitivity of all of the perturbation operands. Often, the only computations that need to be performed are for the one tolerance operand that has been changed. This is where OpticStudio's tolerancing cache options can speed things up significantly.
In the “Set-Up” tab of the Tolerancing dialog, there is a “Cache” drop-down setting with three options:
When sensitivity or inverse sensitivity analysis is run, the criterion values for the max and min of each tolerance operand are saved in a cache in memory. If the “Cache” setting is set to “Recompute All” for the next tolerancing run, the criterion values are once again calculated for each tolerance operand as usual.  If “Cache” is instead set to “Recompute Changed”, the criterion values are only computed for the tolerance operands that have been changed or added since the last tolerancing run.  This can greatly speed up the tolerancing process.  Likewise, “Cache” can be set to “Use Polynomial” to make use of polynomial fits to speed up the tolerancing process.  For more information on this option, please see the Knowledgebase article, “What is Polynomial Sensitivity Tolerancing?"
OpticStudio will automatically clear the cache if any of the tolerancing settings (i.e. criterion choice or sampling settings) are changed. OpticStudio will not, however, reset the cache if changes are made to the lens data in a given file. The cache should only be used when no changes have been made to the lens system that is being toleranced. If changes are made, set the “Cache” setting to “Recompute All” in the next tolerancing run.
When using the cache feature, compensator data are not displayed in the tolerancing summary at the end of each tolerancing run (though the criterion values shown do consider the effects of compensation). Likewise, separation of data by fields and configurations is not supported when using the cache feature.
KA-01499
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
