This article will show what components of MS Visual Studio need to be installed to use ZOS-API with C# or C++ and create a Standalone Application, a User Extension, a User Analysis or a User Operand.
Authored By Kaleb Niall
Disclaimer
Zemax LLC does not officially support or endorse any of the following software or products. The views and opinions expressed in this article are those solely of the author, who is a Zemax employee, and these are only provided as guidance for other users of the ZOS-API to help get started.
Installing Visual Studio
To use C++ and C# with with ZOSAPI, it is highly recommended to use an Integrated Development Environment (IDE) when writing your C++ or C# code. Microsoft offers a community edition of their Visual Studio (https://visualstudio.microsoft.com/vs/) IDE which is what this author uses. Visual Studio provides code completion, syntax error checking, a built-in console, and a debugging tool with break points. This last feature is one of the best features of the IDE since you can inspect the properties of any object in the ZOSAPI environment.
When installing, make sure to install the three core Windows workloads and any other supplementary workloads desired.
When the download process is finished, launch OpticStudio and try some examples!
C++ Example
Let’s try a simple example to compile and run some code in C++. Open OpticStudio and navigate to the “Programming” tab. Open a new Standalone Application from the C++ dropdown.
This will open Visual Studio with the “Boilerplate” C++ code which will establish a connection with OpticStudio when run. This code can be accessed by expanding the “CppStandaloneApplication” line in the Solution Explorer and then clicking on “CppStandaloneApplication.cpp”
Now we will be able to add in custom code on line 55 where is says “// Add your custom code here…”. Try pasting in the code below. This code, which is taken from the API Syntax Help Example 1, will set up a simple sequential system and then use the quick focus tool to bring the image plane into focus. It will then save the system as “e01_new_file_and_quickfocus.zmx” in Documents\Zemax\Samples\API\CPP.
// creates a new API directory
CreateDirectory(_bstr_t(TheApplication->SamplesDir + "\\API"), NULL);
CreateDirectory(_bstr_t(TheApplication->SamplesDir + "\\API\\CPP"), NULL);
// Set up primary optical system
_bstr_t sampleDir = TheApplication->SamplesDir;
_bstr_t testFile = sampleDir + (_bstr_t)"\\API\\CPP\\e01_new_file_and_quickfocus.zmx";
// Make new file
TheSystem->New(false);
TheSystem->SaveAs(testFile);
ISDMaterialCatalogDataPtr(TheSystem->SystemData->MaterialCatalogs)->AddCatalog("SCHOTT");
// Aperture
ISystemDataPtr TheSystemData = TheSystem->SystemData;
TheSystemData->Aperture->ApertureValue = 40;
// Fields
IFieldPtr Field_1 = TheSystemData->Fields->GetField(1);
IFieldPtr NewField_2 = TheSystemData->Fields->AddField(0, 5.0, 1.0);
// Wavelength preset
bool slPreset = TheSystemData->Wavelengths->SelectWavelengthPreset(WavelengthPreset_d_0p587);
// Lens data
ILensDataEditorPtr TheLDE = TheSystem->LDE;
TheLDE->InsertNewSurfaceAt(2);
ILDERowPtr Surface_1 = TheLDE->GetSurfaceAt(1);
ILDERowPtr Surface_2 = TheLDE->GetSurfaceAt(2);
ILDERowPtr Surface_3 = TheLDE->GetSurfaceAt(3);
// Changes surface cells in LDE
Surface_1->Thickness = 50.0;
Surface_1->Comment = "Stop is free to move";
Surface_2->Radius = 100.0;
Surface_2->Thickness = 10.0;
Surface_2->Comment = "front of lens";
Surface_2->Material = "N-BK7";
Surface_3->Comment = "rear of lens";
// Solver
ISolveDataPtr Solver = Surface_3->RadiusCell->CreateSolveType(SolveType_FNumber);
Solver->_S_FNumber->FNumber = 10;
Surface_3->RadiusCell->SetSolveData(Solver);
// QuickFocus
IQuickFocusPtr quickFocus = TheSystem->Tools->OpenQuickFocus();
quickFocus->Criterion = QuickFocusCriterion_SpotSizeRadial;
quickFocus->UseCentroid = true;
ISystemToolPtr baseTool = quickFocus;
baseTool->RunAndWaitForCompletion();
baseTool->Close();
// Save and close
TheSystem->Save();
Once this code is copied into Visual Studio, it can be compiled and run by pressing Build… Build Solution and then Debug… Start Without Debugging. Check out the new file that is saved in the CPP folder after the code is run. Feel free to change some of the values or lines in the code to start customizing the system. Be sure to hit Build… Rebuild Solution after making edits to the code.
C# Example
The C# procedures will be very similar to C++. This time, open a new Standalone Application from the C# dropdown in the programming tab.
Visual Studio will open automatically, and the “boilerplate” code can be accessed by clicking on the “Program.cs” line in the Solution Explorer. Just like in the C++ example, custom code can be pasted after the line “// Add your custom code here…” The code below is the C# version of the code in the previous example.
string strPath = System.IO.Path.Combine(TheApplication.SamplesDir, @"API\\CS");
System.IO.Directory.CreateDirectory(strPath);
string sampleDir = TheApplication.SamplesDir;
string testFile = sampleDir + "\\API\\CS\\e01_new_file_and_quickfocus.zmx";
// Make new file
TheSystem.New(false);
TheSystem.SaveAs(testFile);
TheSystem.SystemData.MaterialCatalogs.AddCatalog("SCHOTT");
// Aperture
ISystemData TheSystemData = TheSystem.SystemData;
TheSystemData.Aperture.ApertureValue = 40;
// Fields
IField Field_1 = TheSystemData.Fields.GetField(1);
IField NewField_2 = TheSystemData.Fields.AddField(0, 5.0, 1.0);
bool slPreset = TheSystemData.Wavelengths.SelectWavelengthPreset(WavelengthPreset.d_0p587);
// Lens data
ILensDataEditor TheLDE = TheSystem.LDE;
TheLDE.InsertNewSurfaceAt(2);
ILDERow Surface_1 = TheLDE.GetSurfaceAt(1);
ILDERow Surface_2 = TheLDE.GetSurfaceAt(2);
ILDERow Surface_3 = TheLDE.GetSurfaceAt(3);
Surface_1.Thickness = 50.0;
Surface_1.Comment = "Stop is free to move";
Surface_2.Radius = 100.0;
Surface_2.Thickness = 10.0;
Surface_2.Comment = "front of lens";
Surface_2.Material = "N-BK7";
Surface_3.Comment = "rear of lens";
// Solver
ISolveData Solver = Surface_3.RadiusCell.CreateSolveType(SolveType.FNumber);
Solver._S_FNumber.FNumber = 10;
Surface_3.RadiusCell.SetSolveData(Solver);
// QuickFocus
IQuickFocus quickFocus = TheSystem.Tools.OpenQuickFocus();
quickFocus.Criterion = QuickFocusCriterion.SpotSizeRadial;
quickFocus.UseCentroid = true;
quickFocus.RunAndWaitForCompletion();
quickFocus.Close();
// Save and close
TheSystem.Save();
The code is compiled and ran in the same way by pressing Build… Build Solution and then Debug… Start Without Debugging.
More Examples
There are some extra examples that can be found in the ZOS-API Syntax Help (Programming… ZOS-API Help…)
Note that these are complete examples, and already include the “boilerplate” code. They can be pasted into a blank C#/C++ editor and will be able to connect to OpticStudio.
Previous article: Required OpticStudio version and language for using ZOS-API
Next article: Understanding the basics of ZOS-API structure
KA-01817
Comments
