How to load an OpticsBuilder (.ZBD) file for Creo Parametric
This article is part of the Getting Started with OpticsBuilder free tutorial.
OpticsBuilder saves time and increases productivity by enabling fast and flawless conversion of lens design data into native CAD platforms. With one click users can start faster by not needing to recreate the geometry of optical components. Get it right the first time and avoid errors introduced by manually creating optical components, maintain optical fidelity by loading the entire optical design, including lens materials, positions, sources, wavelengths, and detectors. Design packaging faster by easily viewing boundary rays and using mathematically driven optical geometry.
Authored By Jacob Hart
The Prepare for OpticsBuilder tool in OpticStudio 20.1 and higher ensures that all supporting data is grouped with the optical design. The data includes (but is not limited to): the lens material, coatings, source definition, and manufacturing drawing data. The resulting OpticsBuilder (.ZBD) file loads all necessary information into the CAD software. With one click OpticsBuilder saves time and increases productivity by enabling fast and flawless conversion of lens design data into a native CAD platform.
Loading a .ZBD file
From a new assembly file in Creo:
1. In the ribbon, click Import .ZBD file.
2. In the Open ZBD file explorer window, navigate to /Documents/Zemax/Samples/OpticsBuilderCreo/Heliar and select the Heliar_37mm.zbd file.
3. There are two options under Locate:
  • Mate into existing design – loads the optical design as a sub-assembly
  • Start new design – loads the optics design as parts in the top-level assembly
Note: Use 'Mate into existing design' when adding an optical system to an already existing mechanical assembly. Use 'Start new design' when starting a new assembly with the optical system.
4. Click Open. OpticsBuilder will load all optical components into the graphics area automatically and display the boundary rays.
KA-01957
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
