Can I share my software license with a colleague?
The answer depends on the type of license you have. If you have an Ansys license (License numbers starting with 1-) , these are considered Network licenses and have the rights below.
Individual licenses
Individual licenses are not intended to be shared between colleagues, though they can be transferred from one person to another, such as in the event of staff turnover. Full details about individual license policies can be found in Zemax's Licensing Policies
Network licenses
Network licenses are designed to be shared between colleagues. Each end user will also need to install the application software on their machine.
Legacy licenses
For more detailed instructions, see How to configure the keyserver and clients for Zemax network licenses.
Ansys licenses
(License numbers starting with 1-) do not use "end users". All license access is controlled from the license server not from the "end user" list. See Configuring Zemax applications to access an Ansys license and Restricting access to an Ansys license on a license server
Was this article helpful?
1 out of 2 found this helpful
Comments
0 comments
